bringitonskippy
Feb 29, 2016Aspirant
Unable to reset N300RE range extender
I was pointed in the direction of Netgear by the On Networks support page (http://support.on-networks.com/) so I'm hoping someone can help. I bought an On Networks N300RE Range Extender a couple ...
DarrenM
Mar 01, 2016Sr. NETGEAR Moderator
Hello Bringitonskippy
Have you tried to connect to the device via ethernet to re setup the extender I posted a link to the manual here and you can follow from page 8 how to log in.
http://updates1.on-networks.com/support/N300RE/UM/N300RE_UM_26April13.pdf
DarrenM
greatgranpat
Mar 05, 2016Aspirant
Hi, Having the same problem, unable to get rid of the last hookup and factory reset not working. I don't have access directly to the router, in a shared wifi setting in an rv park. Any suggestions?
