wyemtnbav
Sep 21, 2019Guide
Unexpected behavior using EX3700 through GS105 switch
I hope I've posted to the relevant board. I purchased an EX3700 to attempt to bring wifi from my house to my workshop. Connection was spotty, so last week I ran copper cable from the router (in the h...
- Sep 22, 2019
Its sounding more and more like its a switch or cable issue.
How long is the cable?
Have you tested the cable and seperately tested the switch?
wyemtnbav
Sep 22, 2019Guide
Yes, that is exactly how the devices are set up. It occurred to me that something had reset itself - I just leave everything powered up all the time - but I was baffled at the AP providing LAN connection to a computer plugged in next to it on the same switch! I guess part of me just wants to understand how that occurs, even if it's not the root of the problem! I'll follow your suggestions and report back later today! Thank you!
wyemtnbav
Sep 22, 2019Guide
Okay, so I was utterly unable to connect to the web using the AP.
I unplugged it, took it in the house, did a factory reset, updated the firmware, and set it up again as an access point. Everything went flawlessly. I even renamed its dual outputs to avoid any confusion. Plugged directly into the router, I was able to log in and out of the 2.4 / 5 networks with so trouble at all. I saved the configuration, then unplugged the AP from the wall outlet for 60 seconds. When I plugged it back in, it booted right up and I was once again able to access both wireless outputs.
I thought that had it sorted so I brought it back out to the workshop and plugged it into the ethernet switch. It now displays both wireless outputs, but won't let me sign into either, giving me a "file 404" error message. If I try to sign in using the Netgear utility, it says the AP isn't connected to the router. I tried more than one ethernet cable, just to be sure that wasn't an issue.
Thanks again for your assistance!
- plemansSep 22, 2019Guru - Experienced User
- wyemtnbavSep 22, 2019Guide
The cable is 72" but I swapped with my laptop cable and the laptop still connected fine. I also tried other ports on the switch. One thing I'm uncertain about is the connectivity LED adjacent to each port on the switch. The cables going to my other wired devices each have an led illuminated next to their respective ports on the switch, but the AP cable's port won't light, no matter which port it's in. I'm thinking about grabbing a new cable on my way home from work tomorrow, just to be sure. One thing's certain: the AP either wasn't correctly configured or lost it's settings prior to my initial help request, so you were spot on there! If I can just get the thing online, I'll be set. Heck, the switch is only ~$20 so I'll buy another if I have to! Thanks again for your continued assistance!
If you plug the cable directly into the AP without the switch, does it work?
- wyemtnbavSep 23, 2019Guide
A new cable solved the problem. Odd, since I was able to connect directly to the router using the SAME cable! Anyhow, thanks again for your help. Aside from the cable connectivity issue, the unit wouldn't be working if you hadn't suggested the first steps. Cheers!
