Gamer_merlin's avatar
Jan 30, 2022
UPload speed is not the same.
I have a NIGHTHAWK router, RAX43 ( AX4200)   just got it in decemeber,  i am a twitch stream  and for the whole week my upload speed has been give me problems.,    so when i do the test from the router " SPEEDTEST Powered " thru the app on my phone..   it show the upload speed at 7.9 Mbps   but when i go to my computer, i do a speed test from the " speedtest by ookla" on the website  it show an upload speed of 0.23 Mbps.  why is not the same,  i can't stream,  if my upload speed is low.   is my router broken ?  can any one tell what the problem is ??,    this is really mess up my side income.  and it driving me crazy. please help.
  • plemans's avatar
    Jan 30, 2022
    If you hardwire a pc into the modem, what speeds do you get?
    Are you testing your speeds on the router hardwired in?
  • plemans's avatar
    You have the RAX200?
    What firmware is on it?
    What modem/gateway is it connected to?
    • Gamer_merlin's avatar
      Gamer_merlin
      Guide
      The moderm is from optimum the cable company.     "ARRIS "  and the router says the firmware is update to day.
      1. I did a factroy  reset, already it did not work.
      2.  also the speed when i did from the wifi  also show it slow.
      3. only the netgear app, test  show the connect is fast.
      • plemans's avatar
        What arris is it?
        And sometimes the auto-update doesn't function as it should.
        so what actual version are you on?
