Noojd
Dec 25, 2017Aspirant
Use R6220 as a repeater, problems with settings
I´m trying to set my R6220 as a (wired) repeater in an existing wireless network. The main router is a Inteno EG300 (which not makes me very happy...) and when I try to set the R6220 as a repeater mo...
TheEther
Dec 25, 2017Guru
You want to use Access Point (AP) mode. Go to ADVANCED > Advanced Setup > Wireless AP and turn it on. Follow the onscreen instructions.
Noojd
Dec 26, 2017Aspirant
Thanks a lot for your answer! But, If I choose to repeat an existing network, shouldn´t the setting be "Wireless repeating function"? I want to have one wifi network (or two, 2,4 and 5). When I try to choose that setting I get this message:
"The wireless repeating function cannot be used with Auto Channel.
Please change your channel settings before you enable the wireless repeating function."
I can´t seem to find the menu where I chenge the channel setting.
- TheEtherDec 26, 2017GuruSince you will wiring the R6220 to your EG300, you want to use AP mode. Wireless repeating mode is used for wirelessly connecting the R6220 to the EG300. Wireless repeating is much slower and less reliable. You should used wired connections whenever possible.
- NoojdJan 21, 2018Aspirant
Thanks a lot for you answer!
