laurelinme
Mar 04, 2017Tutor
username and password
Hi , I can't find anymore my username and the password for the repeaters and so I'm stuck cause I can't access my extended wifi connection in the house . Does someone know how to reset it ? thanks in...
- Mar 04, 2017
There is a physical button to reset it to factory settings. The button may be recessed inside a hole. If you don't have the manual, you can download it from support.netgear.com.
laurelinme
Mar 04, 2017Tutor
I did what you've said , it's written in the manual to enter this site http://www.mywifiext.net/ , the problem is I don't have access to it , don't know why , any ideas ?
TheEther
Mar 04, 2017Guru
You have to be connected to the extender's Ethernet or Wi-Fi network in order for www.mywifiext.net to work.
- laurelinmeMar 04, 2017Tutor
thanks for your kind support ! I was able to etablish once again a connection with my repeaters ! have a nice weekend .
