DeeBeeEff
Sep 09, 2018Aspirant
Using an underscore in a SSID name
Hello,
I don't really know where to put this, but since my EX6200 is the most recent addition to my home network, I thought I would put this here.
I use the EX6200 in AP mode, and aside from my c...
- Sep 13, 2018
You can have an underscore in an SSID name. Can you provide a link to the "blurb"?
You can of course try temporarily replacing the underscore (perhaps with a dash) and see if the symptoms change.
Sep 13, 2018Guru - Experienced User
- DeeBeeEffSep 13, 2018Aspirant
Stephen,
Thanks for your reply. I couldn't find the info about underscores. I think it is in one of the Smart Life instructions in the app, but their web-site is in Chinese, so their support is limited.
Some day when I have several hours, I will rename the SSID without the underscore and see if that changes things.
Thank you for taking the time to reply. :catvery-happy:
Dave
