JD777
Sep 14, 2016Aspirant
Using multiple AC750 range extenders in the same house?
Can I use two or more AC750s in the same house for more extensive/better wifi coverage?
- Sep 16, 2016
Hello JD777
Yes you can but its not recommend to connect 2 extenders to each other you will want to make sure to connect them both to the main router.
DarrenM
DarrenM
Sep 16, 2016Sr. NETGEAR Moderator
Hello JD777
DarrenM
