JD777's avatar
JD777
Using multiple AC750 range extenders in the same house?
Can I use two or more AC750s in the same house for more extensive/better wifi coverage?
  • DarrenM's avatar
    Sep 16, 2016
    Hello JD777
    Yes you can but its not recommend to connect 2 extenders to each other you will want to make sure to connect them both to the main router.
    DarrenM
