YoungDave
Dec 09, 2017Aspirant
Using N300 Wifi Range Extender to connect Sony Bravia 46EX520
I have connected the N300 to the Sony Bravia TV 46EX520. The TV indicates Internet Connectio but wont update software via download and shows an internet error message.
I am wondering if the TV settings have the correct IP Addrees, SUbnet MAsk, Default Gateway, Primary DNS, Secondary DNS. I'm not sure what they should be. Appreciate any help.
Cheers
Thanks, this turns out to be an issue with Sony Entertainment - Thanks
- DarrenMSr. NETGEAR Moderator
Hello YoungDave
It depends on what the IP address that your router is using if you have a netgear stand alone router it will be 192.168.1.xxx if its a netgear router/modem combo its 192.168.0.xxx
DarrenM
- YoungDaveAspirant
