YoungDave's avatar
YoungDave
Using N300 Wifi Range Extender to connect Sony Bravia 46EX520
I have connected the N300 to the Sony Bravia TV 46EX520. The TV indicates Internet Connectio but wont update software via download and shows an internet error message.
I am wondering if the TV settings have the correct IP Addrees, SUbnet MAsk, Default Gateway, Primary DNS, Secondary DNS. I'm not sure what they should be. Appreciate any help.
Cheers
  • Thanks, this turns out to be an issue with Sony Entertainment - Thanks
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello YoungDave
    It depends on what the IP address that your router is using if you have a netgear stand alone router it will be 192.168.1.xxx if its a netgear router/modem combo its 192.168.0.xxx
    DarrenM
    • YoungDave's avatar
      YoungDave
