bradwjames
Jul 18, 2017Follower
Using N300 Wireless extender ethernet port for a desktop
Hi
There is an ethernet port on the bottom of the extender. Can I use it internet access by plugging the ethernet cable from a desktop computer into it? I tried but the computer does not appear to see the internet connction.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello bradwjames
yes you should be able to use this port if the extender is connect via wireless to your main router.
DarrenM
