securigroup's avatar
securigroup
using WN3000RPv3 to extend iphone personal hotspot
hi guys, hoping you can help; I have a WN300RPv3 wifi range extender. What i am trying to do is connect the extender to my iphones personal hotspot so i can then connect a device via the patch lead out the bottom of the extender - in other words use the device to give a hardwired unit the internet from my phone. When i try to set the unit up i cant find the phones personal hotspot - am i doing something wrong? thanks for any help
  • StephenB's avatar
    Is the hotspot creating a 2.4 ghz wifi network, or 5 ghz?
    The WN3000RPv3 is limited to 2.4 ghz.
    • securigroup's avatar
      securigroup
      Hi thanks for your reply. A quick search of the internet shows an iPhone as being 2.4ghz but not entirely sure
      • StephenB's avatar
        Perhaps also leave the personal hotspot screen up on the phone while you connect the extender to the hotspot network.
  • I did not see an anwer to this so here we go ...
    After trying to set-up a WiFi extender for my iPhone 5 it appears Apple does not use the standard ascii character set for the SSID they brodcast. This causes some extenders not to see the correct SSID during set-up. When they rebroadcast the SSID as an extender the phone will not connect to it.
    I have tried four manufactures models (TP-Link , D-Link,Netgear and Linksys).
    The only on that worked was the Linksys RE6400. Hopes this helps and saves someone the pain I went through.
    • Sparra's avatar
      Sparra
      Hi pub1809,
      Did you try connecting a Windows10 PC to the iPhone hotspot and then connect the extender to the PC?
      Sparra
      • pub1809's avatar
        pub1809
        I was successful connecting a PC with Windows 10 OS using a Ralink and Linksys AE6000 USB wireless adapter to the extender which was connected to the iPhone 5 with the cell phone data and mobile hotspot enabled giving the PC access to the internet. The speeds could not be tested accurately because I am in the country with poor cell phone service. My cell phone provider assures me they will be enabling a block of LTE towers. This exercise was preparation for cell phone service enhancements.
        FYI .... also worked on XP with the Linksys AE6000 USB adapter but not the XP,Ralink combination. I have not tried the eithernet port on the extender.
  • Hi, maybe it has become easier to connect devices to iPhone hotspots in August of 2019. I connect my PC through an iPhone hotspot using the lightning cable (USB). It is fast & sturdy and than on from the PC you can setup a (private) LAN network or a wireless network if you like. It needs (LAN) only a connected Router (PC LAN). These routers are cheap now to obtain. In Windows 10 it is possible to pause all syncing in the background because you use a SIM (metered connection). Your data (rate) usage will be considerebly lower.  Expect speeds up to 30+Mbps. That seems sufficient even using Netflix in HD. I never use more then 2.5GB on a daily basis wich is within the 5GB daily standard limit of a unlimited 4G account. You do the math?
  • Iphones can't have cell data and wifi on at the same time. You must set up your iphone as a hotspot using cell data. Use another device to set up the range extender that can have the wifi turned on, like an ipad, or another iphone.
