Micken4
Jun 04, 2016Follower
Very slow download/upload speed on extender wifi
I use my extender on the first floor of my house (modem is in the basement and I'm on the second floor). For some reason, the speeds on the EXT network have actually been worse than connecting to the wifi in the basement. Not sure what the problem is, I've tried resetting the network extender, but the settings are no different than they were when it was working much better a week ago.
I'm not sure why or how the extender is actually giving me worse performance than the network it's extending.
Any ideas?
- DarrenMSr. NETGEAR Moderator
Hello Micken4
This is normal with wireless extenders it will cut the wifi speeds in half so it should be slower than the normal wifi network unless you are using it as a access point using a ethernet cord.
DarrenM
- flmclInitiate
then why use the extender if wifi signal is less?
Hello Flmcl
to get more range on your wifi connection in the home. We just launched out latest product Orbi that is a router with a satellite unit that provides more wifi coverage in the home with out the speed loss you may want to check it out.
http://www.netgear.com/home/products/networking/orbi/?cid=wmt_netgear_organic
DarrenM
