BretD
Jan 12, 2018Administrator
Video: Meet the Nighthawk Mesh WiFi Extenders!
NETGEAR's Current Nighthawk Mesh WiFi Extenders:
EX8000 - X6S Desktop Nighthawk Mesh WiFi Extender
EX7500 - X4S Wall Plug Nighthawk Mesh WiFi Extender
Do you have a Nightha...
pwcoghlan
Mar 04, 2018Aspirant
I have the EX8000 X6S Extender and using as an Access Point. Both the user guide and various Netgear articles suggest I can enable "one WiFi name"; however it only appears in the wireless setting a menu prior to Smart Setup. If I attempt to select it, I receive a message stating I must run Smart Setup before I select "one WiFi name". I do this but I cannot then go back to set the option as when I open settings / wireless, this option (enable / disable buttons) and another to sync configuration appear momentarily as the page loads and then disappear. I have tried several options using different SSID names (different from the current Netgear R7500 router); factory reset etc. but no difference. I have raised a ticket for help as although I have set the SSIDs to the name SSID of the R7500 router I'm not convinced it's working as it should. The link explains the process to set "One WiFi name" but this has the same resut as above. Firmware # ends in 118 which is the latest. Guidance welcome. Thnx
https://kb.netgear.com/000044735/How-to-log-into-the-Nighthawk-Tri-Band-WiFi-Range-Extender
jvasanth1984
Mar 10, 2018Virtuoso
Hi pwcoghlan,
One wifi name feature is not applicable for AP mode and is only for extender mode.
