kusojiji
Jul 05, 2018Tutor
VIRTUAL MAC ADDRESS
While trying to connect the EX8000 to my R7800, the R7800 detects several different MAC addresses from the EX8000. The EX8000 shows 4 virtual MAC addresses in the connected device status page.
DarrenM
Jul 12, 2018Sr. NETGEAR Moderator
You should be able to add the mac address on the box to the white list of the router. If not have you tried to add all of them?
DarrenM
- kusojijiJul 12, 2018Tutor
Hi,
The box has 8C:3B... MACs that do not show up at all in my ACL as blocked or allowed. I see 92:3B and 02:0F MACs in the ACL, with the same last 3. The 92:3B attaches itself to IPs that are assigned to other devices and roams around.
It doesn't make sense.
Thanks for the reply.
- lehigh1Aug 26, 2018Aspirant
I am having the same problem. The IP address for 2G of EX8000 is on some virtual IP address. How do I resrve it ??
- StephenBAug 27, 2018Guru - Experienced User
The extender needs to relay the packets from the client to the router, and it needs to keep track of the two data flows. Translating the old mac address to a new one to the backhaul packets is a simple way to do that.
There is information on this on page 32 of the EX8000 manual here: http://www.downloads.netgear.com/files/GDC/EX8000/EX8000_UM_EN.pdf
