kusojiji
Jul 06, 2018Tutor
VIRTUAL MAC ADDRESS
While trying to connect the EX8000 to my R7800, the R7800 detects several different MAC addresses from the EX8000. The EX8000 shows 4 virtual MAC addresses in the connected device status page.
kusojiji
Aug 27, 2018Tutor
Sorry, I don't get it. How does this translate to the EX8000 having multiple MAC addresses? I understand the translation for devices connected through the EX8000, but not the EX8000 itself.
I ended up having two MAC addresses that seem to be required, the rest don't seem to be needed. I don't f-around with this thing too much anymore, but adding new devices is a real pain.
Thanks!
Aug 28, 2018Guru - Experienced User
Your post didn't give enough details to know if the MAC addresses were for the EX8000 itself or were for devices connected to the EX8000.
The EX8000 will of course have it's own IP address - allowing you to reach it's web ui from your main network. I'm away from home at the moment so I can't confirm what you are seeing with my own EX8000.
If you use MAC ACL white-listing, there is of course some extra work. Personally I don't bother with MAC ACL, under the theory that anyone with the skills to crack WPA-2 also has the skills to spoof MAC addresses.
