Degas
Dec 22, 2018Aspirant
VIRTUAL MAC ADDRESS
My EX8000 had connected the router of ASUS RT-AC5300 via 5G signal, and PC workstations are connected by LAN cable, after connected almost one day, PCs will have a virtual mac address and connected t...
Degas
Dec 27, 2018Aspirant
Hi Christian,
Thank you for your reply.
1. My extender had been updated to newest firmware but the result is just the same.
2. MAC address haven't filtering or access control enabled on my router.
Christian_R
Dec 28, 2018NETGEAR Employee Retired
Hello Degas - I have sent you a message. Please respond at your earliest convenience.
~Christian
- DegasDec 29, 2018Aspirant
Hi Christian,
I think I have been solved the problem, it might be wifi channel problem, I set the router channel bandwidth and control channel from auto to fixed, and it is seem stable now, I hope the extender connection could be stable in future.
Thank you for your help.
Best Regards,
Degas
- Christian_RJan 04, 2019NETGEAR Employee Retired
Hi Degas - Thanks for the update! Please feel free to let us know if we can be of any assistance.
~Christian
