1_Heiko
Mar 03, 2015Novice
wall mounting of WAC120?
Is there a nice solution for wall mounting of WAC120? - I want to place it just blow the ceiling. Heiko
RX
Mar 03, 2015Luminary
@1_Heiko: Since the design of the WAC120 is for desktop deployment... I would recommend that you place it as high as 5ft. or more up from the floor. However, it would be your option if you want to improvise a mounting bracket if ever you really want to place the WAC120 to be mounted at the ceiling or side-wall. :D
