PeterTheSbam's avatar
PeterTheSbam
Web-based authentication for Ex 3700
I bought an EX3700 to log into the Telstra Air network (same as the FON network).  The network requires browser-based authentication, where you log in with a username and password at a web page (like in airports).  I can't seem to achieve it.  Does anyone have some advice?  If it is not currently possible, is that capability in the firmware upgrade pipeline?
  • Hello PeterThesbam
    The Ex3700 will not work with this type of network if it needs to use a web based login it can only connect via SSID and password or WPS. And no information on if this will be possible in the future.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello PeterThesbam
    DarrenM
    • PeterTheSbam's avatar
      PeterTheSbam
      Hi Darren,
      Do you know if any Netgear range extenders are capable of web-based authentication?
      Peter.
      • DarrenM's avatar
        DarrenM
        Hello PetertheSbam
        We have 1 extender that does do that the PR2000 all others do not.
        DarrenM
