CrunchDude
Apr 06, 2008Novice
WG602 v3...Cannot get into config utility!???
Hi all...Can someone please tell me as to how I can get into the wireless settings. I guess I mean the IP address for the AP. It's supposed to be 192.160.0.1, or 192.168.1.1, correct? Well, I have...
aechmea
Apr 07, 2008Aspirant
CrunchDude wrote: Hi all...Can someone please tell me as to how It's supposed to be 192.160.0.1, or 192.168.1.1, correct?
I doubt it. From memory the default IP address as shipped from the factory is 192.168.0.227.
Maybe you should do a "factory" reset, connect your computer by ethernet, and do your set-up from the beginning.
The user maunual is linked from here
http://kbserver.netgear.com/products/WG602v3.asp
