CrunchDude
Apr 06, 2008Novice
WG602 v3...Cannot get into config utility!???
Hi all...Can someone please tell me as to how I can get into the wireless settings. I guess I mean the IP address for the AP. It's supposed to be 192.160.0.1, or 192.168.1.1, correct? Well, I have...
siradlib
Apr 14, 2008Aspirant
Did you try to factory reset your WG602v3?
After that, you should be able to open config page by surfing to http://192.168.0.227
For me, getting the unit to do a factory reset was somewhat tricky, so I wrote down the steps for this here: click!
