CrunchDude
Apr 06, 2008Novice
WG602 v3...Cannot get into config utility!???
Hi all...Can someone please tell me as to how I can get into the wireless settings. I guess I mean the IP address for the AP. It's supposed to be 192.160.0.1, or 192.168.1.1, correct? Well, I have...
jedijurist
Jul 28, 2011Aspirant
I am having the same problem, and I have reset the AP several times (holding down the button for more than 10 secs), have followed the directions to a T, and it still only get "IE can't display the webpage" error instead of the login box. I had this on a network, and it worked great. Then I changed routers and network names and just wanted to update it - couldn't log in to the AP. Nothing works, IP or MAC login.
Please help!!!
Please help!!!
