Cooper001's avatar
Cooper001
WG602 v4 No Administrative Console
I have connected the WG602 to my router and am able to connect wirelessly to the internet(I am using it now) I cannot connect to the GUI (192.168.0.227) It says that the server timed out?
Can anybody help me get past this as I would like to add security.
  • Your router's IP address may have been changed.  If you are on Windows, use ipconfig in a Command Prompt to find the address of your router.  It will be listed under "Default Gateway".  This link shows an example under the heading Discover the IP subnet of the existing LAN.
1 Reply
