npoe25
Sep 16, 2010Aspirant
wg602v4 setup
Ok im trying to do the setup procees tht came with the instructions... I get to step 2a and it says enter 192.168.0.227 and i do but nothing happens! It talks about changing the static ip address and subnet mask but i have no clue what its talking about. All im tryin to do is make it a repeater as it says clearly on the box i can... i already have internet on my computer but i want to pick it up on my ps3. Please help
- Daedalus01AspirantHave you tried holding the reset pin for 30-60 secs?
- motatnetAspirantYes, I did the reset pin. I can't say if I held it for 30-60 seconds, however. I guess I could try it again.
- Daedalus01Aspiranthitting the reset pin for a second or so usually doesn't wipe out the NVRAM, you usually have to hold it, and i recommend anywhere from 30-90 seconds.
- jmizoguchiVirtuososee rouer reset on my sig below.
0-60sec in various duration is for resetting - Daedalus01AspirantRight. Maybe something has buggered his config settings, which is why I am recommending a reset now before sending the device back. Its always best to reset, restart, and retry before sending the hardware off.
- jmizoguchiVirtuososupport will never issue RMA until you do certain process and reset it ALWAYS #1 on the list. :)
- motatnetAspirantSUCCESS!
Two things I attribute this to:
Also, did it on yet another PC, this one at the office.
NOW, I can really get into trouble. I hope Client Mode will let me use the unit (wired to PC) like a common PCI wireless card.
Thanks much for the Reset Guide !!
Regards
Tom - jmizoguchiVirtuosoYour welcome.. enjoy it.
