bugg's avatar
bugg
WGR614 DHCP Login Problem
Hi Everyone, i recently bought a new Netgear WGR614 wifi router. I'm currently using a ISP provider which requires login everytime(atleast once in some time if i dont logout) i need to use Internet.
Here how the Login Page Looks like:
http://tinyurl.com/crebsko (Neither PPPoE, nor the another one - It's DHCP Login Type)
I need to enter the username(Email) and Password to authenticate.
The problem is that i dont have the facility in some of the gadgets that are wifi connected. So, i need to everytime switch on the PC and authenticate it and then use the wifi connected device.
I want to know whether in anyway i can login automatically inside the router. I mean any application/script that can do the job for me.
Something like app goes to url, searches the Form id, text box... and fills it up by itself(preloaded username/passwrd) and authenticates automatically.
I would appreciate any opinions. I may need to change my ISP if i'm not able to solve this.
ThaNKS IN aDvance.
  • make sure your DSL in bridge mode and under basic settings of the WGR, supply the correct PPPoE user/pass and that's it
    Hi jmizoguchi,
    I've provided the link above. Please have a look at it. The login type is not PPPoE. It was said by the Customer Care that it is DHCP type of login.
    So, PPPoE type login will(might) not work in this case.
  • link doesn't seems to bring you are referring to
    if you ISP don't use PPPoE but but use login then possible will not work. post exactly the ISP uses from their site or something.. :)
    Here's the link login.hath way.com (or) http://login.hat hway.com/bsp/startportal.do (REMOVE THE SPACES)
    Screenshot:
    Anything like sending a collection of packets everytime when router is switched ON will also do....
  • that is will not going for with ANY router... that is accessing the portal
  • sounds like ISP problem and not router.
    I saw the screenshot, if not I would have not gave you the prior suggestion.
    URL you just gave is nothing but complaints that ISP has changes to user to login from the portal. Router can not assist that :)
  • Ok, Thanks... I knew well that it's the problem with ISP, that's why i said i will have to change the ISP, when i was talking b4. Iwas bit unsure abt solving this prob, and i'm sure now.
    Thanks You.
    No Reply Please
