Tanac99
Aug 02, 2016Follower
What do I put where it says "passphrase"??
Hi, I have the netgear wifi extender model #WN1000RP I recently got a new wifi router and have not been able to reconnect my extender. When I try to set it up with the netgear genie it asks for a pass...
DarrenM
Aug 04, 2016Sr. NETGEAR Moderator
Hello Tanac99
You will want to put in the password that you used for the new routers wireless and if that does not work you will want to factory reset the wifi extender by holding down the reset button for 10 seconds. You should be able to setup the extender again.
DarrenM
