chukka55
Jun 12, 2025Aspirant
What Extender to purchase
I currently have a Netgear AC1000 Dual Band Wifi Router in my 1 level 2400 Sq Ft home. I need to get an Extender to get a stronger signal to the master suite in the back of the house. I DO NOT want t...
- Jun 12, 2025
Thanks everyone. This has been very helpful!
chukka55
CrimpOn_old
Jun 12, 2025Star
Almost any WiFi Extender would probably work. I have been most successful with TP-Link and Netgear WiFi extenders.
TP-Link RE315 sells for under $25 on Amazon. (Overall Pick on Amazon). If it doesn't work, you are not out much.
Be aware that WiFi extenders keep devices on the same local IP subnet as the primary router network, but mobile devices may not roam seamlessly between the primary WiFi system and the WiFi extender (even if they both have the same - identical - WiFi SSID & password). Thus, it may be necessary to "turn WiFi off and back on" to get the iPhone to switch from one to the other. This is the reason mesh WiFi networks were created a decade ago.
