ArizonaJim's avatar
Dec 13, 2016
What is the technical difference between extenders ex6120 and ex6920
What is the technical difference between the ac1200 ex6120 and ex6920 extenders? I purchased ex6920's yet Netgear Geine says there ex6120's?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello ArizonaJim
    Yes they look to be the same unit I guess it had a different model number because it was a pack of 2 extenders.
    • Two (2) AC1200 WiFi Range Extenders (EX6120)
    DarrenM
  • Darren..thanks..I'm looking for the technical differences other than you can buy the dual pack ex6920's...there's a big difference in cost between the different models and configuration..can anyone add to this???
    • DarrenM's avatar
      DarrenM
      Hello ArizonaJim
      That is because it is a ex6120 are you having a issue with the setup?
      DarrenM
      • ArizonaJim's avatar
        ArizonaJim
        Tutor
        Hello Darren, Ya I'm getting the same answer, To me Netgear is misleading it's customer base to use a model# implying your getting the latest device and not just a packaging of 2 model ex6120's. Thanks
