james2720502's avatar
james2720502
when using EX7300 as access point with R8500 router can use same SSID?
Will the ex7300 in access point mode connected with the R8500 router allow the use of the same SSID?  If used in that fashion, will it create a mesh type network with easy hand off from one access po...
