james2720502
Jul 28, 2016Aspirant
when using EX7300 as access point with R8500 router can use same SSID?
Will the ex7300 in access point mode connected with the R8500 router allow the use of the same SSID? If used in that fashion, will it create a mesh type network with easy hand off from one access po...
ElaineM
Aug 01, 2016NETGEAR Employee Retired
Normally, the feature you seek is not available with Home products.
This can only be found with the Business product line such as WAC720.
james2720502
Aug 01, 2016Aspirant
ElaineM,
Thank you.
Jim
- ElaineMAug 01, 2016NETGEAR Employee Retired
You're welcome.
Have a great day!
