Mr_Fatty
Apr 14, 2014Follower
Why New _EXT Network Connection?
Yesterday I installed my WN3000RP range extender with the help of Netgear TS.  The install created a new WiFi network connection with _EXT after my network name.      So the range extender is using th...
marc311
Apr 17, 2014Aspirant
Mr_Fatty wrote: Yesterday I installed my WN3000RP range extender with the help of Netgear TS. The install created a new WiFi network connection with _EXT after my network name.
So the range extender is using that _EXT network. I don't get that, as all my devices are on the regular home network. How is this helping to extend the range for my home devices???
_EXT is the default name just to avoid confusion. You can change it if you want to. =)
