tomnolan's avatar
tomnolan
Novice
Apr 05, 2015
WI FI on I-Pad
I have NETGEAR WGR614 v6 I am able to get on the main computer but am unable to get WI FI on our phones and I-Pads. Rebouted several times with no success. Any suggestions?
    Hi,
    WiFi on iPAD or iPAD on WiFi? What happens if you go through network connection from your i{PAD?
  • You have to view the available networks using your phone and iPad. Connect to your wireless network. Type the network key (if you have security enabled) and that should be it.
    For iPad:
    Settings > Wi-Fi > tap your network
