24008943's avatar
24008943
WIFI- extender + Password problem
Hi , have a  N300 extender ,model no. EX2700 , but after following the set-up procedure ,cannot enter my router password on my i-pad when i try to join the internet  (says incorrect password ) is this a extender glitch or a problem on my i-pad.....am not very pc literate so " be gentle " with pc jargon please .
Rob.
    • 24008943's avatar
      24008943
      Hi ,thanks or the posting ,will save the link for future referance.
      Managed to get up and running with the extender today , my pal is more pc literate than i so he had a look at it .
      The problem seemed to be that as my ipad was already linked to my router and was working ok ( this was before i bought the extender) , then when i then tried to connect it to the extender without deleting the orignal network link , it was ok for a  few weeks as it accepted the password,etc, but for whatever tech reason it seems to have "lost its memory" as regards to my password on the _EXT link.
      What he did was to  click " forget this network" on the direct link to my router ,then he re-joined using the _NET link ,it accepted the password and bingo it worked ok.
      So it seems my router eventually did not like having both network links to the same router , as even when it was connecting ok it would at odd times change network links on its own accord ,i.e switch from TALKTALK ABCD9WB   to TALKTALK  ABCD9WB_EXT ( hope this makes sense).
      By the way can I connect more than 1 device thru the EXTENDER link please ?
      Thanks,Rob.
      • M1309's avatar
        M1309
        I am having the same problem but I am on an iMac (desktop). I have a  wn250rp range extender. Any sugesstions? What works for the ipad is NOT working for the iMac
