Kafe84's avatar
Kafe84
Wifi 5 GHz channel 0
(english is not my native language)
I have an EX6200v1 and I use it as access point.
I can't set or change the channel. Now the channel is set to "0" as you can see.
Connection to Existing Network (5GHz)
    Connection Type Ethernet
    Connection Status Connected
Access Point Wireless Settings (5GHz)
    Name (SSID): Extender5
    Region: Europe
    Channel: 0
    Wireless mode: Up to 867 Mbps
    Wireless AP: On
    Broadcast Name: On
    Wi-Fi Protected Setup: Configured
The extender's firmware version is V1.0.3.76_1.1.111
Whenever I try to change or set a channel I receive this message "You select a DFS channel, the channel will be changed automatically if any Radar is detected.".
I've tried all the channels and nothing worked.
I have an ex6150 and I don't have issue with its 5GHz.
Please help me.
  • I have made a reset, downgraded the firmware to the version V1.0.3.68_1.1.104, and made another  reset but nothing changed.
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello Kafe84
      The extender could be following the main routers channel on the 5ghz band.
      DarrenM
