rybones
Jun 03, 2024Aspirant
Wifi dropping out ex6110
Modem: tplink VX220-G2v I have set up the extender and it works fine for maybe a day, then internet drops out and won't stay connected, even when connected won't load anything. Then I turn off and o...
rybones
Hi thanks for your reply plemans. I try and go to mywifiext .net or mywifiext.local (I am using a MacBook) and the page will not load. It just says it's loading. I have tried resetting browser clearing cache and history and it still does the same thing. Any way to help with this?
Jun 04, 2024Guru - Experienced User
You can try a different pc or browser.
Did you reset it and its during connection to set it up that you see this?
