SteveHaywood
Dec 28, 2018Aspirant
WiFi ext password error
I set up everything just fine but when it comes to put in the password it’s unable to connect. I’m sure the password is correct. Any suggestions?
Dec 28, 2018Guru - Experienced User
Is this the password to join the wifi network, or the password needed by www.mywiifiext.net?
- fatboy91755Dec 29, 2018Aspirant
My extender connects to the router just fine. But when trying to connect my devices it asks for the WiFi password and it will not accept it. The quick start guide says it's supposed to accept the same password that was originally used with the router. Any suggestions?
- SteveHaywoodDec 29, 2018AspirantIt’s the password to join the network, the second option, connecting via http://www.mywiifiext.net/ won’t work at all.
- StephenBDec 31, 2018Guru - Experienced User
SteveHaywood wrote:
It’s the password to join the network, the second option, connecting via http://www.mywiifiext.net/ won’t work at all.To use the second option, you need to reset the extender with a paper clip. You should then see a network called NETGEAR_EXT. You join that network (no password needed), then browse to http://www.mywifiext.net
