SteveHaywood
Dec 28, 2018Aspirant
WiFi ext password error
I set up everything just fine but when it comes to put in the password it’s unable to connect. I’m sure the password is correct. Any suggestions?
Dec 28, 2018Guru - Experienced User
Is this the password to join the wifi network, or the password needed by www.mywiifiext.net?
SteveHaywood
Dec 29, 2018Aspirant
It’s the password to join the network, the second option, connecting via http://www.mywiifiext.net/ won’t work at all.
- StephenBDec 31, 2018Guru - Experienced User
SteveHaywood wrote:
It’s the password to join the network, the second option, connecting via http://www.mywiifiext.net/ won’t work at all.To use the second option, you need to reset the extender with a paper clip. You should then see a network called NETGEAR_EXT. You join that network (no password needed), then browse to http://www.mywifiext.net
