cylon's avatar
cylon
Tutor
Feb 06, 2020
WIFI extended - who is connected?
How can i figure out who is connectedto my wifi extended? I know who is connected to my router but not the extender, thanks
  • thanks - it dosent work with Firefox, had to switch to Edge, now I see them, thanks again
    • plemans's avatar
      If you mark it as solved it helps the next person find the the answer faster as well as it helps prevent others from trying to fix the issue when its already been solved. :)
      Enjoy!
