Vincent2232
Jul 12, 2023Tutor
Wifi Extended EX2800 Not working
My wifi extender for some reason is not work. I have tried to factory reset and that hasn’t worked. My modem is working just fine but for some reason this one just is unusually slow and unusually not ...
- Jul 14, 2023
correct
Vincent2232
Jul 12, 2023Tutor
Thanks for the help! However when I try this it cannot reach the ‘www.mywifiext.com’ website it won’t work because there’s no wifi. When I try to connect it via WPS and than visit the website it says I’m not on my extenders wifi even though I am
Jul 12, 2023Guru - Experienced User
If you connected via wps, try logging into the router and finding the extenders IP address. Use that IP address to access it
- Vincent2232Jul 12, 2023TutorSorry I’m not the best with technology, would I just go to the wifi settings, get the IP address of the extended wifi, and plug that into the mywifiext website? Thank you for your help I appreciate you!!!!!
- plemansJul 14, 2023Guru - Experienced User
correct
- Vincent2232Jul 16, 2023TutorOh my gosh it finally worked! Just wanted to reply and say thank you again for the help I appreciate you 🙂
