Topi's avatar
Topi
Wifi Extender 6120
I have set this up correctly but internet it not available on 5Gz. On my main router the both the 2.4 and 5 wifi signals are transmitted perfectly and no issues with the internet.But from the extender only 2.5 works and though my device can see the 5gz extended signal and connects there is no internet available. Tried every thing but not sure what the issue is?
Any ideas?
  • Hi Topi,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Topi,
    Welcome to the community!
    1. What is the firmware version of the extender?
    2. Have you tried resetting the extender?
    3. Does the issue persist on all your devices when connected to the 5GHz band of the extender?
    4. Have you tried changing the wireless channel for the 5GHz band on the main router?
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Topi,
      Dexter
      Community Team
      • Topi's avatar
        Topi
        DexterJB wrote:
        Hi Topi,
        Dexter
        Community Team
        DexterJB wrote:
        Hi Topi,
        Dexter
        Community Team
        Hello,
        Sorry have been extremely busy. Unfortunately it doesnt work!!! I beleive it is not connecting to the 5G reception from my router. I have attached some pics and hope it can help to throw some light on my issue. My 5G connection from the Asus router works with all devices without any issues. Can connect on the 5G extend....but no internet. Please help.
