TonyGasson's avatar
TonyGasson
Initiate
May 02, 2025
Wifi Extender 6120
Hi, I have just changed router and while I have successfully paired the Extender 6120 to the router my devices cannot access the Extender as the new router password is not recognized by the Extender. I have tried several factory resets but no difference. As I cannot access the extender I also cannot access any wifiext. sites for browser set up. Any help gratefully received
  • Same problem/problems! This is the worst range extender I've ever worked with and I've been in IT for 30+ years! I've run the setup several times using MacOS, and Windows but it will only provide internet access via 2.4gHZ. The 5gHZ will not work. Also, when trying to update the firmware it keeps telling me there's no internet. But it still has internet on the 2.4.
  • michaelkenward's avatar
    michaelkenward
    Is that the wifi password or the admin password?
    If you need to access the controls of the EX6120 (I assume) is it in Access Point mode or extender mode? Did you use WPS to set it up?
    Can you see the wifi from the Extender?
    www.mywifiext.net doesn't work?
    How about the router? If you can access that, look at its list of attached devices for the EX6120. See if you can get into its controls using that IP address in a browser.
    To save that hassle in future, check the bit ion the manual Set Up the Extender to Use a Static IP Address
    Disclaimer: Just another user with time on their hands.
    • TonyGasson's avatar
      TonyGasson
      Initiate
      Thank you Michael. I got into the extender with the IP address as you suggested and the 5ghz extension is now connecting to my devices with a new password but for some reason the 2 ghz appears switched off. Any further suggestions? Thank you again
        michaelkenward
        TonyGasson wrote:
        ....5ghz extension is now connecting to my devices
        Remember, the extender does not connect to your devices. It is the other way round.
        Devices connect to the router.
        They decide which channels to use. They'll go for 5 GHz to get the speed, falling back to 2.4 GHz if they are too far from the router.
