Trafford1's avatar
Jun 07, 2020
WiFi extender AC1200
Hi when I’m trying to connect my Xbox one to my WiFi extender the device light goes a solid green then goes again and on my Xbox it says it can’t connect can anyone help
  • plemans's avatar
    Jun 09, 2020
    glad to hear you got it working with the assistant!
    If you mark it solved, it can potentially help others with this issue in the future.
  • plemans's avatar
    What extender are you using? ac1200 is a speed
    What router are you connected to?
    Are any other devices having issues or just the xbox?
    what firmware is the extender on?
    • Trafford1's avatar
      Trafford1
      Tutor
      It’s an ac1200 extender and I’m connected to a technicolour WiFi and yeah all devices are having the same issue I even factory reset it and tried again and when I put the correct password in the device light goes green and then goes off again after a second and says I have put the incorrect password on
      • plemans's avatar
        Trafford1 wrote:
        It’s an ac1200 extender-----Not a model. See above. and I’m connected to a technicolour WiFi ----also not a model. and yeah all devices are having the same issue I even factory reset it and tried again and when I put the correct password in the device light goes green and then goes off again after a second and says I have put the incorrect password on
        Please add the models.
        Did you setup the extender using wps or the installation wizard.
