optheatre
Feb 15, 2016Aspirant
Wifi Extender and ReadyShare
Wifi Ext WN3000RPv3
Router DGN2200
I've recently got an extender which works really well at extending the signal but I can't access any files on the USB ReadyShare Drive attached to the router.
I can't find anywhere where it says you can't do this but neither can I find anywhere claiming you can so thanks for any help at all!
- doraemonProdigy
How do you access the files?
The extender shouldn't be preventing you from accessing it.
- optheatreAspirantI access it via a shortcut on my Windows 7 desktop which works fine if connected directly to the router (and in near proximity) but if I use the same shortcut when connected via the extender then I get a popup saying 'Network Error' 'Windows cannot access \\READYSHARE\USB_Storage'.
