Memnochthedevil's avatar
Aug 01, 2022
WIFI extender (EX6100) won't connect to router
Hello everyone! So my extender was working fine for a few months but yesterday I was having some issues, reset it and now the wifi light isn't turning on, when I try to set it back up "NETGEAR_EXT" never shows up in my wifi. It won't show up under my products on the nighthawk app. I've also tried factory resetting my main router and using a different device. The troubleshooting website just says to connect to NETGEAR_EXT and follow the set up wizard but I can't do that. Let me know if I need to provide any further details. Thanks
  • So your leds are showing its powered on and a device is connected to it. just not a router.
    Try hardwiring a pc/laptop into the extender and logging into the extender. From there you should be able to re-run setup on the extender.
    Just make sure that the pc/laptop you connect to it doesn't have the wifi on or it can default to the wifi connection
  • plemans's avatar
    You reset by pushing and holding reset for 7-15 seconds while powered on?
    Are any of the lights on? If so, what color and what leds?
    • Memnochthedevil's avatar
      Memnochthedevil
      I have and did again. The wps light is on, the power light is on but wifi light isn't on. Actually lol I'll just attach a picture of it
  • plemans's avatar
