Jaysch's avatar
Jaysch
Initiate
Feb 08, 2022
WiFi extender ex6110
My WiFi extender won't accept my new routes password,how do I get it to accept the new password?
  • plemans's avatar
    What router are you connecting it to?
    What method of setup did you use? WPS?
    • Jaysch's avatar
      Jaysch
      Initiate
      It's a vodaphone router and I use WPS set up
      • plemans's avatar
        what vodafone router? (some are pretty sketchy)
        Try setting up the extender using the installation assistant. So factory reset the extender and then use the installation assistant.
