ACLambert's avatar
ACLambert
Follower
Oct 18, 2018
WIFI EXTENDER EXS6190
Hi, I've just had NBN FTTN installed.  I have a Netgear EXS6190 wifi extender which I used previously but I'm having trouble connecting it to the Gateway modem.
Does anyone know whether they are incompatible?
1 Reply
  • StephenB's avatar
    They should be compatible.  The simplest approach would be to use the same network names and passphrases in your new router as you used in the old one.
