Davidkay's avatar
Davidkay
WiFi extender firmware thru nighthawk
Why does nighthawk tell me to update the firmware when I just installed it AND it upgraded firmware during that process. Plus the support for trying to update FW is sending me in circles. Their web pages need some TLC.
  • plemans's avatar
    What extender do you have?
    What firmware is on it? How are you attempting setup?
    • Davidkay's avatar
      Davidkay
      I followed the three step directions for setup. It said it updated firmware during the process.
      Now, the nighthawk app says the firmware is not up to date.
      I have tried reinstalling the app.
      The extender seems to work, but I can’t get past the update request to check speed connected devices, etc.
      I Went to router login.net, logged in as admin, but when it asks if I want to update firmware, there is a black button bar across the bottom, that I assume cuts off the y/n button.
      • plemans's avatar
        Davidkay wrote:
        I followed the three step directions for setup. ---what three steps? It said it updated firmware during the process.
        Now, the nighthawk app says the firmware is not up to date.---so what version are you on?
        I Went to router login.net, logged in as admin, but when it asks if I want to update firmware, there is a black button bar across the bottom, that I assume cuts off the y/n button.---try a different device or browser? maybe its a browser issue.
        And finally What extender are you using?
