JodyR
Nov 09, 2016Aspirant
Wifi extender has incoming signal but no outgoing signal
My wifi extender shows a green incoming signal but my device says no internet service. The extender is 2 years old. It started doing this a couple of months ago. I have reset to factory settings with no luck. How do I fix it?
- DarrenMSr. NETGEAR Moderator
Hello JodyR
Try to factory reset again but make sure you are holding the reset button down for atleast 10 seconds.
DarrenM
- JodyRAspirantI'll try that, thanks.
- JodyRAspirantTried that and it didn't work. Still says no internet connection. I just hope I don't have to get another one at $70. I'll totally do something different.
