amm274
May 20, 2026Aspirant
Wifi Extender in Metal Shop
Hi. I'm not very good with technology, so I'm hoping someone can help me out. I have a metal building that is ~4800 sq ft. We ran cable from my house to the shop and connected it to a router. Wifi i...
- May 20, 2026
WiFi cannot penetrate metal walls. Install Ethernet cable from the router to the other two rooms and place WiFi access points in them.
CrimpOn
May 20, 2026Guru - Experienced User
amm274
Thanks for the info. Can you connect one access point to the other or do they have to have separate ethernet cables that connect to the router?
