amm274
May 20, 2026Aspirant
Wifi Extender in Metal Shop
Hi. I'm not very good with technology, so I'm hoping someone can help me out. I have a metal building that is ~4800 sq ft. We ran cable from my house to the shop and connected it to a router. Wifi i...
- May 20, 2026
WiFi cannot penetrate metal walls. Install Ethernet cable from the router to the other two rooms and place WiFi access points in them.
amm274
Thanks for the info. Can you connect one access point to the other or do they have to have separate ethernet cables that connect to the router?
May 21, 2026Guru - Experienced User
amm274 wrote:Thanks for the info. Can you connect one access point to the other or do they have to have separate ethernet cables that connect to the router?
I'd just run two cables. It's about the same amount of work and gives you more flexibility later on.
